pcm ? - FirebirdV6.com/CamaroV6.com Message Board
pcm ?
  • pcm ?
    i read in one of the forum rooms that if you change your pcm you could use a hhp111 with a 99 firebird i know this is a stupid question but what is pcm and if it would work is it better than the jet products i also saw that someone said that they took there screen out of maf how is that done and would it help
    By changing the pcm, you are basically replacing your computer with that of another year. The HPP3 is better than the Jet Chips because you actually re-program your computer and have many more options.
    As for removing your maf screen, do a search and read up on the pros & cons before doing this mod.
    <a href=\"http://www.cardomain.com/id/sac2165\" target=\"_blank\"> CAMAROS</a>
