hey bobbyz72, thanx for all the help and info on bleeding and flushing the coolant, it was alot of help, i changed the thermo, water pump, flushed it, and......hope you dont mind, but i did the coolant tank mod you made. [img]graemlins/banana.gif[/img] worked out great! ill post pics later tonight after work.
once again thanx alot for the help.
FOR SALE: 94 3.4 camaro <a href=\"http://www.cardomain.com/ride/2193648clutch240@yahoo.com\" target=\"_blank\">http://www.cardomain.com/ride/2193648clutch240@yahoo.com</a><br />my import with a touch of american muscle..... <a href=\"http://www.cardomain.com/ride/2090657\" target=\"_blank\">http://www.cardomain.com/ride/2090657</a> <br />\" Im getting a foot-print gas peddle installed, so i stole this pile.\"
YOUR WORKING ON NEW YEARS DAY???!!!! That sucks,,, show me the pics!!!
hahaha, thats great. Hows you battery mounted, did you just cut the neck off the coolant tank? Because thats the point i was trying to get a cross in my pic with mine cut off, even though i totally removed mine. I see 2 things you need to do, in the cap of your new coolant tank you need to punch or drill a "SMALL" hole in it so it can breath and the cap wont blow or pop off when the bottle starts to fill, again a small hole you dont want it to splash out. Second that clear hose that comes with the tank has a very thin wall thinkness and was wanting to kink at the ratiator. All i had to do was go to the hardware store and pick up a new piece. I'm MUCH MUCH happyer with the new tubing, but they may have since corrected the problem and your tubing may be fine. Glad you like it. I seached a long time looking and thinking how to do this mod and my battery mount, because mine was in bad shape. And this tank jest fits perfect in that spot!
Oh and hows the temps running, did this correct your over heating problems?
temp is great now! and i just broke the tray from the tank and remounted it, the tray was in good shape. yeah that hose is pretty thin, it was trying to kink but i routed it so that it(hopefully) wont kink. but im thinking of upgradeing it soon too. thanx for the tip on the vent hole, that could have been bad..
thanx for the help man!
