Anyone else have this? It almost seems as if something is turning on and off every 5 or 6 seconds. Its really annoying. it is coming from under the hood, I have no idea where though. Any ideas?
Clicking sound every 6 seconds or so at idle
1993 3.4 <br />Borla rear section<br />3 inch Catco High Flow Cat<br />2.75 inch I pipe (Picked one up from an LT-1 guy for a whole $10)<br />K&N Fipk <br />180° T-stat<br />Jet Stage II<br />10 Spoke Z28 Wheels<br />NGK\'s, Taylor Spiros<br />Mobil 1 synthetic<p>Email Viper2@chesnet.net for 4th gen replacement parts.Tags: None
is it your AC compressor?Justin96Bird / Justin98TransAm<p>1998 Navy Blue TransAm<p>Whisper Lid<br />free ram air<br />K&N Filter<br /><a href=\"http://www.hhbc.com/justin96bird/index.htm\" target=\"_blank\">DynoMouth Exhaust</a><p><a href=\"http://www.hhbc.com/justin96bird/index.htm\" target=\"_blank\">http://www.hhbc.com/justin96bird/index.htm</a>
I was just going to ask the same question. If you have your A/C on then thats the noise otherwise I'm not sure. Do you know where it is coming from, which side, etc?1994 Camaro<br />3.4L V6 Automatic<br />K&N FIPK&Gold Oil Filter,Ravin Performance Exhaustw/Dynomax MandrelBent3\"I-Pipe&S Pipe&Catco 3\" HiFlow Cat.,ASP Crank and High AMP Alternator,U.D. Pulley Set, Bosch Spark Plugs and Oxygen Sensors, Taylor Wires, B&M E.ShiftPlus, 160 thermostat,Zexel Torsen L.S.D., CSI Remote Mount Electric Water Pump & Temp. Controller & Flex Hoses, ALM. Drivshaft, Diamond SubFram Conn.<br />COMING SOON: 350 or 502 RAMJET ENGINE & Big Block Hood<br />NJ V6 F-Body Club<br /><a href=\"http://tristategm.com/NJFbV6/\" target=\"_blank\">http://tristategm.com/NJFbV6/</a><br />Street Lethal F-Body Association <br /><a href=\"http://www.slfba.com./index.html\" target=\"_blank\">http://www.slfba.com./index.html</a>
The old compressors would chick in and out when the refrigerant was low. The new ones might as well.1995 Firebird 3.8 A4, 140,000 miles and going strong<br />Basically Stock, college=poor <p>Junior Mechanical Engineering Student: Milwaukee School of Engineering; Cpl, MN Army National Guard...just got promoted :)
Ok I will check that. The sound basically sounds like something is turning on and off kind of like th efan going on and off but I am not sure. I will try to find the prob.1993 3.4 <br />Borla rear section<br />3 inch Catco High Flow Cat<br />2.75 inch I pipe (Picked one up from an LT-1 guy for a whole $10)<br />K&N Fipk <br />180° T-stat<br />Jet Stage II<br />10 Spoke Z28 Wheels<br />NGK\'s, Taylor Spiros<br />Mobil 1 synthetic<p>Email Viper2@chesnet.net for 4th gen replacement parts.
I found the exact spot where the sound is being made. it is right where the AC compressor is. I think it is either the compressor, of the belt. The belt is kind of old and needs to be replaced anyway. Why would the AC compressor be clicking anyway? It clicks even when I first start my car in the morning and let it idle with nothing on (no ac, heat, anything else)1993 3.4 <br />Borla rear section<br />3 inch Catco High Flow Cat<br />2.75 inch I pipe (Picked one up from an LT-1 guy for a whole $10)<br />K&N Fipk <br />180° T-stat<br />Jet Stage II<br />10 Spoke Z28 Wheels<br />NGK\'s, Taylor Spiros<br />Mobil 1 synthetic<p>Email Viper2@chesnet.net for 4th gen replacement parts.
I'm gonna have to say that's pretty normal from what you're discribing. Does it draw power when it "clicks on"??? could be your cooling fan... I think you're just getting fussy like we all do from time to time [img]smile.gif[/img]1994 Camaro 3.4L M5 R.I.P.<br />You know what they say- a small engine means big... errr... e/t\'s<br /><a href=\"http://www.pbase.com/rrj72/the_accident\" target=\"_blank\">www.pbase.com/rrj72/the_accident</a><p>replaced with: red 97 A4 vert (my brothers as soon as i find my REAL replacement)<p>soon to come: 1969 RS/SS<p>\"All you need are the esentials: scented candles, massage oil, and Berry White write that down.\" -Van Wilder
Yes I am pretty sure it draws power because my dash dims just a little bit. I dont think i am just being picky because this clicking noise is LOUD. People outside my car hear it loud and clear, and say "what is that clicking noise".1993 3.4 <br />Borla rear section<br />3 inch Catco High Flow Cat<br />2.75 inch I pipe (Picked one up from an LT-1 guy for a whole $10)<br />K&N Fipk <br />180° T-stat<br />Jet Stage II<br />10 Spoke Z28 Wheels<br />NGK\'s, Taylor Spiros<br />Mobil 1 synthetic<p>Email Viper2@chesnet.net for 4th gen replacement parts.
