engine swap... - FirebirdV6.com/CamaroV6.com Message Board
engine swap...
  • engine swap...
    hey guys im thinking of doing an engine swap from a 3.4 to a 3.8 / 3800 / or an LT1 which would be the best for the buck...
    for the LT1
    http://sfbay.craigslist.org/eby/pts/435157978.html
    as it says it came from a caprice 9c1 cop car... do you guys think it would fit? because the LT1 that I know looks different than this one... or is it just that plastic thing on top of it?
    Horsepower is how fast you hit the Minivan... Torque is how far you take the Minivan with you... :wavey:
    Originally posted by Firehawk N Wv
    Mine were rusted also and the I had to cut my nuts off .
    Re: engine swap...
    That LT1 is awfully far from you...
    Yeah, it's the same though. The only difference is the that it had iron heads instead of aluminum. If you want aluminum heads you need an LT1 from an F Body or a Corvette.
      Re: engine swap...
      wahahahah my bad i didnt knew i was typing on a bad reply thingy....
      well from what i know the LT1 came with an iron head.. and the LS1 came with the aluminum ones... or did they both came with aluminum? so does that mean this engine wont fit in my f-body? :(
        Re: engine swap...
        It will fit, it just has big heavy heads
          Re: engine swap...
          the only lt1 that came with iron heads are the caprice and impala lt1s.
          iron heads suck. heat soak kills all flow.
          the motor will fit, but the heads are junk. (keep in mind impalas are only rated at 245hp and the lt1 found in the caprice is called the baby lt1,its a under bored lt1, with **** heads)
          hold out for a motor from a fbody or vette.
          Follow me!
          Or this
            Re: engine swap...
            hold out for an fbody lt1. Supposedly, the vette ones are angled different inside the heads on the first 2 years, not sure hwta that means, but yea
            Car expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
              Re: engine swap...
              I believe the 'vette ones are rated at a higher horsepower, too.
                Re: engine swap...
                Aren't the accessories on the Vette ones arranged different?
                  Re: engine swap...
                  Hey vanbibber:
                  The baby LT1 is the L99 that was used in the caprice it's a 4.3 litre V8 265 cubes. It has the same apearance and looks exactly the same as the LT1 exept for stroke, bore and the rods are longer. It was rated at 200hp and 260 ft-lbs of torque. The 5.7 litre was also used in caprices but not all 9c1 caprices are LT1 cars, some have the L99.
                  Got rice?
