Heat went out - FirebirdV6.com/CamaroV6.com Message Board
Heat went out
  • Heat went out
    Well my heat went out and I don't feel like dropping $500 or so at a scam shop to have it fixed, what components will I need to replace and is it difficult to fix? What else could have caused it to fail? I can bring it to my family mechanic and hell fix it for like $50 if its not too hard. Let me know ASAP! Thanks!
    Re: Heat went out
    Probably the heater core, from what ive heard, HUGE B!TCH to replace
    *Matt
      Re: Heat went out
      i know the heating system like the back of my hand. find out when went dead and i'll tell ya how to fix it!!!
      WAWA-A-HOLIC
        Re: Heat went out
        im just glad i never even have to touch my heater :)
          Re: Heat went out
          i did the a/c delete. and usually when people do that and start to take stuff out, the heat goes with it. so i had to really fab up alot of stuff to keep the heat. rips out my whole interior last week.
          WAWA-A-HOLIC
            Re: Heat went out
            ok im gonna take it to a shop and just see whats wrong with it and let you know kristen, i have a digi so i can take pics and if its not TOO difficult i can get a walkthrough? haha
              Re: Heat went out
              update: im like 90% positive its the heater core that went out...where exactly is it located in a 2000 camaro? and how much am i looking at price wise to have a shop fix it?
                Re: Heat went out
                it wouldn't be hard to replace yourself. the heater core is about 70 bucks. it's behind your pass side glove box.
                remove kick cover, glove box(few screws under the box), then you will see a black plastic cover (kinda rounded) right there. take that off. then your core is right there.
                WAWA-A-HOLIC
                  Re: Heat went out
                  as she said... its right behind the glove box. only hard part is snaking the hard lines through the firewall, and sealing them back up. the heater core i bought didnt come with the new seal and they werent available separately, so i improvised. little bit of expanding foam (and when i say a little i mean a little) seals it right up.
                  foggy headlights? wetsand... buff... WAX!!!
                  if nissan motorsports is nismo does that mean honda motorsports is homo?
                    Re: Heat went out
                    this is a sign your camaro doesn't want to drive in the snow!
                    1999 Camaro Z/28
                    1973 Firebird Formula
                      Re: Heat went out
                      damn i got the same problem when i turn my heater on it blow cold a/c air hopefully my warranty will cover it
                        Re: Heat went out
                        oh boy im looking forward to pulling the dash in my car this winter.
                        -Y87
                        Lid,K&N Filter,PaceSetter Headers,Magnaflow Cat 2.5in S-pipe,Flomaster :(,3.42 LSD
                          Re: Heat went out
                          it's a pain in the ***...there are a couple bolts that you need to get off that are kind of hidden so it will seem like its unhooked but magically still attached
                          good luck!
                          1999 Camaro Z/28
                            Re: Heat went out
                            lmfao i took my entire dash out too....what a pain in the a$$. have fun with that. why are you takin it out? are you doing a heater weight reduction?
                            WAWA-A-HOLIC
                              5 days ago
                            • 187shark
                              by 187shark
