I NEED HELP!!! PLEASE ANYONE!!! I AM STRANDED AT WORK
The Maro will not start. For the last few days I have had problems with my ignition-(I was able to turn the key before the alarm sounded-but now the alarm sounds in record speed.) I would have to turn the key a couple times to get it to crank. Its about 80 degrees in ATL today, I attempted to go out to lunch, and now I cannot get my car to crank, I can't even disarm my alarm by turning the ignition. What could possibly be my problem.
Please Guys/Gals I would rather be stranded anywhere but work. Please anybody [img]graemlins/crybaby.gif[/img] [img]graemlins/crybaby.gif[/img]
Take a breather for a few minutes. Now make a real effort to disarm your car without using the ignition. Use your key fob gizmo and put it really close to the receiver. Once you do that, look for an inline fuse coming directly from your alarm box. Pull it. All will be wonderful. :D
\'94 Camaro 3.4<br />\"No, Starvin Marvin. That\'s my pot pie.\"
your thinking about a nuetral safety switch, aren't you? disconnect the alarm for a day or so & see how it does, also get the alt checked for a bad diode/not enough juice. get battery checked same time.
2013 Ram 1500 Big Horn
94 comero 3.4
Has anyone used zzp gt1 cam if so is it worth the money and time
