I NEED HELP!!! PLEASE ANYONE!!! I AM STRANDED AT WORK - FirebirdV6.com/CamaroV6.com Message Board
  • I NEED HELP!!! PLEASE ANYONE!!! I AM STRANDED AT WORK
    The Maro will not start. For the last few days I have had problems with my ignition-(I was able to turn the key before the alarm sounded-but now the alarm sounds in record speed.) I would have to turn the key a couple times to get it to crank. Its about 80 degrees in ATL today, I attempted to go out to lunch, and now I cannot get my car to crank, I can't even disarm my alarm by turning the ignition. What could possibly be my problem.
    Please Guys/Gals I would rather be stranded anywhere but work. Please anybody [img]graemlins/crybaby.gif[/img] [img]graemlins/crybaby.gif[/img]
    Do you have a A4 or M5?
    1996 Y87 Camaro, 175.0 rwhp, 211.6 rwtq.....1/4 15.500@88.54 &lt;----- Needs work!!<br />-CAI, Custom bent S-Pipe, LS1 I-Pipe, Flowmaster 80 series, !MAF, manual fan switch, relocated trunk pop switch, 180 degree t-stat, More to come!<br /> <a href=\"http://camaro.wbisolutions.com\" target=\"_blank\">http://camaro.wbisolutions.com</a> <p>WANTED!!! Naked and handcuffed!
      Take a breather for a few minutes. Now make a real effort to disarm your car without using the ignition. Use your key fob gizmo and put it really close to the receiver. Once you do that, look for an inline fuse coming directly from your alarm box. Pull it. All will be wonderful. :D
        I Have an A4. Thanks for the quick responses
          your thinking about a nuetral safety switch, aren't you? disconnect the alarm for a day or so & see how it does, also get the alt checked for a bad diode/not enough juice. get battery checked same time.
          2013 Ram 1500 Big Horn
          94 comero 3.4
            Guys/gals Please don't- How do I disconnect the alarm???? :rolleyes:
              If you have a starter kill as part of your alarm system, you have to disarm first. Then pull the fuse.
