how do i take the other pully off of the alt? i cant seem to get it off
alt underdrive pully
Re: alt underdrive pully
Are you using a impact or air tools to loosen the nut?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
i have an electric hand socket wrench type thing (kinda like an air gun), but that's it.
how would o go about doing it? i read i can put my car in 5th and then try it. would that work?
Originally posted by Tom Rsu need an impact gun to get it off otherwise the alt will keep spining. did u try it with the belt still on ?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
some one told me i could take a screw driver and stick it in the blades of the alt so it wont spin. would that work?
and its not one of thos reverse pully bolts is it? were you have to turn the bolt to the right to loosen it.
if the blades are plastic they will break, if the blades are metal they will prob. bend. Only way i know of is use of an air tool impact, it should come off easily with one of those.
Originally posted by Meatyshellsand its not one of thos reverse pully bolts is it? were you have to turn the bolt to the right to loosen it.1999 Camaro Z/28
1973 Firebird Formula
yeah was easier than i thought lol
and i just relized that my lil electric power socket gun says impact wrench on the side lolLast edited by Meatyshells; 10-04-2007, 01:01 AM.
