alt underdrive pully - FirebirdV6.com/CamaroV6.com Message Board
  • alt underdrive pully
    how do i take the other pully off of the alt? i cant seem to get it off
    Re: alt underdrive pully
    Are you using a impact or air tools to loosen the nut?
      i have an electric hand socket wrench type thing (kinda like an air gun), but that's it.
      how would o go about doing it? i read i can put my car in 5th and then try it. would that work?
        u need an impact gun to get it off otherwise the alt will keep spining. did u try it with the belt still on ?
        1997 Camaro LS1 RS
        1994 Camaro - Sold
        1999 Trans am Vert - Sold
        A Few Mods....
          Thats true , leave the belt on then once the bolt loosens, take the belt off , but you will need a impact gun for sure to get the nut off.
            some one told me i could take a screw driver and stick it in the blades of the alt so it wont spin. would that work?
            and its not one of thos reverse pully bolts is it? were you have to turn the bolt to the right to loosen it.
              if the blades are plastic they will break, if the blades are metal they will prob. bend. Only way i know of is use of an air tool impact, it should come off easily with one of those.
              I believe it is not...if i remember right i put the impact on reverse
              1999 Camaro Z/28
              1973 Firebird Formula
                i got it off with my lil elctric power socket gun :)
                  that was fast
                  1999 Camaro Z/28
                    yeah was easier than i thought lol
                    and i just relized that my lil electric power socket gun says impact wrench on the side lol
                      glad to hear u got it off.
                      1997 Camaro LS1 RS
                      1994 Camaro - Sold
                      A Few Mods....
                      • 187shark
                        by 187shark
