Test your knowledge... - FirebirdV6.com/CamaroV6.com Message Board
  • Test your knowledge...
    What do you win? Not a damn thing, you can pat yourself on the back if you want I guess.
    Problem: Service engine soon light came on last night
    Car: 2000 3.8 A4
    History: Bought a little over a year ago, change oil reguarly, plugs and wires changed after buying it. Originally was putting 10-15 miles on it a day but in the last 3 months have put around 75 on it daily
    Mods: None, well a Home Depot intake, that's it.
    Symptoms: Slightly rough idle but barely noticeable.
    Car still drives and performs as it always has. I haven't noticed anything screwy with it. I'm going to get it scanned tomorrow as I have no life or time anymore to do it right now. I'll post what showed up tomorrow afternoon until then see if you can throw some stuff out there to guess what's wrong with it or what codes I will get.
    Re: Test your knowledge...
    O2 Sensor Circuit Low Voltage.
    How many miles on the car?
      I want to say around 67k
        my guess would be a small vac leak somewhere. you checked all the lines?
          I looked at it quick last night but haven't had time to check anything in detail. 18 hour days are a biatch.
            i would think some kind of leak. something small if you don't notice anything
            WAWA-A-HOLIC
              I hope so, I don't have the time, energy or money to deal with anything I can't duct tape.
                EGR?
                or coil-pack
                1999 Camaro Z/28
                1973 Firebird Formula
                  Originally posted by badinfluenceRS
                  EGR?
                  or coil-pack
                  EGR I'll remove in a heartbeat.
                  Coil pack god I hope not. I don't have the money, duct tape won't fix it and the mounting bolts are stripped from whatever some previous douche did.
                    Coil would give you a misfire and a flashing SES light.
                    I'm still guessing O2 or other emissions equipment!
                      Thank you, forgot to mention that.
                      The SES light is solid on, not blinking. Right before I changed my plugs it would flash.
                      Ignition can be probably be ruled out.
                        No, I had a bad coil-pack on my 96 rs, it was a steady SES light.
                        1999 Camaro Z/28
                          MAF / dirty or bad, could probably use a throttle body clean
                          *Matt
                            all my guesses have been stated already
                            egr, O2, coil, clogged fuel injector, fuel pressure regulator
                            thats covers my suspects.
                              I'm going to go with the majority here and say O2 or small misfire.
                              • Andy H
                                Transmission removal help!!
                                by Andy H
                              • 2.8 Bird
                                Abs inop
                                by 2.8 Bird
                              • fishin
                                by fishin
