You should probably check out your egr valve and see if its sticking. If it is sticking try and clean it up if you can. Just be careful what you clean with.
Originally posted by youngsc
Got it scanned this morning.
Let me first add this. Hadn't used the a/c at all since it went on. So when I did turn it on the SES went off right away.
It was a P0404 egr flow circuit range
I'm guessing that the a/c generated some extra crankcase pressure thus opening it if it was sticking or temporairly correcting the problem.
So I guess badinfluence was the closest.
3.4ornothing I just placed an order for a brand new engine, I figured that would fix any other oncoming problems j/k
So no big deal for now, when I get time I'll just do the delete on it.
