misfire - FirebirdV6.com/CamaroV6.com Message Board
misfire
  • misfire
    my new car has a misfire in low to mid rpms IN DRIVE, idles/rev's a bit rough but decent in park...
    tomorrow I'm gonna plug the EGR, see if that works
    I ordered new plugs, wire, coil packs, icm
    If that doesn't work I'll order fuel injectors
    I might also cut off the cat tomorrow just in case
    What else can I check? I think i've covered most the 'common' culprits...
    also, it throws a SES but I cannot get it scanned b/c no insurance = i cant drive to ****in autozone
    1999 Camaro Z/28
    1973 Firebird Formula
    Re: misfire
    my car missed fire like that too,,,one night i popped the hood (its was dark) and saw a nice electric spark show from 4 wires.
      Re: misfire
      Whatever you do, don't cut off the cat unless you're absolutely positive that it's causing a problem. I've learned from my mistake.
        Re: misfire
        I had that, replaced my plugs and plug wires. Misfire went away for about 500 miles, then came back :( Not sure why, thinking I might be burning oil and fouling out the plugs or something.
          Re: misfire
          I made some progress today.
          I removed the wires from the 3-6 coil pack and engine idle did not change, when i removed the wires from the other two coil packs, it barely ran when i did that.
          That narrows down the problem to the 3-6 coil pack or plug wires 3 or 6, or spark plugs 3 or 6
          the SES light is flashing so it most likely is an ignition problem
          1999 Camaro Z/28
          • Andy H
            Transmission removal help!!
            by Andy H
          • 2.8 Bird
            Abs inop
            by 2.8 Bird
          • fishin
            by fishin
