that when it rains the water leaks onto the motor to the left of the pcv valve on the 3.8
I have tried everything to stp this andd even cuaked it and numerous other things. its really fin lame. i hope mine isnt the only car that does this.
mine was a foam weather stripping between the black plastic grill under the windshild and the metal. ITs easy to fix
????? you say... no that doesnt fix it. what did u do??????? I dont understand what your trying to say.
I messed w/ the rubber strippin and tried making a better seal in the middle with some goopy stuff and some weather foam stripping. it still leaks. and it pisses me off
