Thermostat Housings - FirebirdV6.com/CamaroV6.com Message Board
Thermostat Housings
  • Thermostat Housings
    As my 3.4 in an MG project continues I find myself using more Fiero parts on the engine - the oil pan is more shallow for ground clearane etc.
    One thing I can't use is the thermostat neck as it includes the filler neck on the Fiero. The Camaro unit points the wrong way for me - to the passenger side of the car.
    Anyone know of one from some variant that points to the left side a bit?
    My current sample is this:
    Fiero = straight up
    Camaro = slightly angled to the right
    3400 transverse = way to the right
    Are there no left leaning housings out there? S-10 or something?
    You'll probably have to fabricate one yourself.
    If it were me... I'd take the transverse Thermo Housing, cut it off near the base, and then re-weld it with the new angle. Alot of people don't have that option, and I don't know of any other 3.4's that can accomodate.
    Good luck though
      Jest reweld like hockeyman said, quick, easy, and cheap. And it will work fine. If you wanna be fancey about it take it to a welding shop and have them do it.
        check summit and jegs i remember seeing one on one of those but i can't remember which one
        K&N air filter, Whisper air lid, magnaflow LT1 cat back, and magnaflow high flow cat, pacesetter headers, silverstars<br /><br />more to come soon<br />but for now im out of money
