what is the best brand of vented rotors and pads. and where can i get them? front brakes are almost gone, and need to replace soon to get inspected. thanks.
looking for the best vented brakes....
pretty much all brake components are going to run you the same amount of money unless you step up to baer or another premier brand like that. most people on this site that use slotted rotors get the powerslot versions; they are about the same price as factory replacements. i (and most people on this board) would personally stay away from slotted or cross-drilled rotors for a few reasons.
Originally posted by j_downey50:
don't wanna hijack the thread or anything, but why stay away from them?<a href=\"http://www.cardomain.com/id/kefkafloyd\" target=\"_blank\">http://www.cardomain.com/id/kefkafloyd</a> <br />Red 1997 Pontiac Firebird 3.8L A4 w/ Y87
From the Mod Encyclopedia
As for the face of the rotors, there are several designs to choose from. Stock F-Bodies come with flat faced, vented rotors. While these are good for dissipating heat, cross-drilled or slotted are even better. Cross-drilled rotors consist of a regular rotor with drill holes lining the face. The holes allow much more heat to be dispersed, and also allow gases and brake dust a means of escaping from the rotor surface. Cross-drilled rotors are not perfect, however. Where the drilled hole meets the flat surface is a stress region that contributes to weakness in the rotor and can lead to cracking. Some companies chamfer the edges of the holes (grind them down to round the edges off) which aids in reducing the stress, but it is still present to a reduced effect. Cross-drilled rotors are, all other things being equal, more likely to crack than flat faced rotors are.
Slotted, or grooved, rotors arose as a response to the problems of cracking with cross-drilled sets. Slotted rotors feature long grooves that are machined into the face of the rotor, giving gas and dust a means of escape. They also dissipate heat much better than standard flat rotors. Because the edges of the grooves are chamfered, no sharp edges arise which can crack. The fault with slotted rotors, however, is that the metal of the rotor is very thin at the site of the groove, leading to problems with them cracking there.
Slotted and cross-drilled rotors do NOT dissipate heat better, they're made to channel away brake gasses which we haven't had a problem with since Asbestos pads. Slotted/drilled are marketing these days. Get good blanks and pocket the difference to put towards good ceramic pads.<a href=\"http://www.cardomain.com/id/kefkafloyd\" target=\"_blank\">http://www.cardomain.com/id/kefkafloyd</a> <br />Red 1997 Pontiac Firebird 3.8L A4 w/ Y87
I use ceramic pads myself. But not everyone does.
A friend of mine put cross drilled on his Probe.
I asked him "If the Viper doesn't come with them, why would you need them?"
I guess the encyclopeida should be updated then?
But I think the one poster was more interested in WHY you would not use them.
I use ceramic pads on my slotted/cross-drilled rotors. I noticed a huge difference when stepping up from the stock rotors. If you get drilled you should know how the maker makes them...make sure they are cast drilled and not drilled afterward, this will cause stress and will eventually crack.<a href=\"http://www.onid.orst.edu/~waltejam/\" target=\"_blank\">98 Bright Red Camaro</a><br />Too many mods to list....check my website
cross-drilled will have less mass and that's probably the only good about them with modern friction materials.
some of the people on ls1tech seem to think the $35 autozone rotors work pretty well. i need some new rotors so i just might try those.
05' CTS-V
00' Camaro - SOLD :(
Originally posted by nikon:
</font><blockquote>quote:</font><hr />Originally posted by Dan Vincent:
And if you have a problem with warping rotors, slotted/drilled won't solve that - bigger/thicker rotors (and generally beefed up brakes) will. Most slotted/drilled motors are made better than OEM blanks - but (most) aftermarket blanks are also very good.
Brake fade can also be caused by several other factors, one of which modern friction materials don't have to worry about is outgassing, and most of the time pad material determines brake fade.<a href=\"http://www.cardomain.com/id/kefkafloyd\" target=\"_blank\">http://www.cardomain.com/id/kefkafloyd</a> <br />Red 1997 Pontiac Firebird 3.8L A4 w/ Y87
Wow. Nice input. I learn new things here everyday. I love this messageboard. [img]smile.gif[/img]<i>00\' NBM Firebird~T-5<br />60\': <b>2.29 sec.</b><br />1/4: <b>14.7 @ 95.5 MPH<br />Ask not what your country can do for you, ask what you can do for me.</b></i>
your right the warping of the rotors can be fixed my thicker brakes....like you said most aftermarket ones are thicker, thats what I went for with my brakes.....so, eh sure were in aggrement ;)
05' CTS-V
you dont need drilled but sloted have proven many time over to stop you faster, i personally can;t say how i like the cross drill/sloted, me i ****ing hate break fadewww.turbov6camaro.com
1997 3800 Series II Camaro
I just used ceramic pads all the way around. My car will stop on a dime. Only thing is one day when I was braking pretty hard, regularly I felt some brake fade. Eventually I will just step up to a LS1 front brake system. Not slotted or drilled of course. Also, one time, to test out an experiment after seeing the 24 hours of lemans. I drove down the last street of my house, with the brakes on, and then pulled in my drive, and then lit a cigarette off my rotor. :D Always wanted to know that after seeing those brake rotors glow in lemans.Jordan<br />15.09@90.7<br /><a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=21\" target=\"_blank\"><b>1995 Camaro 3.4 M5</b></a>
