This may be a totally stupid question, but when it gets really cold, my drivers side lock freezes. This doesnt happen often but turning the key sometimes wont do it so I have to get in the passenger side and unlock it with the power locks. Anyway I didn't think much of it until I noticed that the stiff piece of weather stripping lining the window bwetween the bottom of the window and the door is starting to seperate from the door. It's lifting up and there is now a small gap there. Could water from rain, car washes, melting snow etc be entering my door from this small gap? It may be a foolish question but I dont want my door filling with water slowly and freezing or anything.
Water IN the doors?
Water get's inside of the doors all the time. There is a small hole at the bottom of the door to let water out.
If the seal is coming loose, you'll need to fix it with some weatherstripping adhesive -found at any auto store.
When it's extremely cold here, I take a rag and soak it with WD-40, then rub it over and areas that may freeze together. As for your locks, I'd put some motor oil on your key and work it in the lock a few times to lube it. It may still freeze after that, but it won't take much effort to break the lock mechanism loose.sigpic
I've had the problem of my lock freezing also, lucky for me I have keyless entry.
2000 Pewter Pontiac Transam 360rwhp, 370ftlbs
1998 Sport Gold Metallic Chevrolet Camaro *SOLD*
1974 Silver Chevrolet BIG BLOCK Corvette
Having a problem with freezing..... move here to houston texas...we are always well above freezing.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
