can the crossmember be removed. i as looking under the car today and i dont understand how u can remove are motors fromt the bottom with the crossmember right underneath the motor. can some one please explain. thanks
crossmember
Re: crossmember
i believe it's called a "k" member, the cross member is what the trans sits on.
But i think if you can find a way to prop up the engine, the k member should pull out mayb?
Re: crossmember
if you are gonna pull the motor like that, it all comes out as one unit. the enigne cross member and front suspension actually drop out from under the car, actually you lift the car off the motor and stuff. never seen anyone other then horsepower tv do it that way all the techs just pull it from the top.96 camaro auto base model<br />slp cai<br />pacesetter headers<br />flowmaster catback<br />35th anniversary ss wheels<br />richmond 3.73<br />98+ ss spoiler<br />hypertech 160 degree thermostat<br />transgo shift kit
Re: crossmember
The Tech Manual Actually Says To Jack Or Tilt The Motor.96 camaro auto base model<br />slp cai<br />pacesetter headers<br />flowmaster catback<br />35th anniversary ss wheels<br />richmond 3.73<br />98+ ss spoiler<br />hypertech 160 degree thermostat<br />transgo shift kit
