Well its really not a themastat problem but just a question. What would be a problem with not having a thermastat at all. What would be some downsides to it.
thermastat problem
Well not having a thermostat will cause your car to take longer to heat up, because there will be colant flow when your car is cold taking heat away as the engine tries to warm up.
Secondly, when the thermostat is in the open position it still provides a slightly restricted flow from the size of the orifice through which the coolant flows. Just taking out the thermostat out would cause the engine to actually overheat, becuase without any restriction the colant would flow too quickly through the engine to acutually remove any heat from the block or heads.
Trust me, if you are gonna take it out you at least have to have some kind of partial block of plate with a 1/2" to 3/4" orifice. You would have to experiment to determine which size would give you optimum performance.
Really you are just asking for more trouble, thermostats were invented for a reason, its probably best to just let them do their jobs. Without one your cars temp would most likely be all over the scale depending on outside temperature, and how fast you were going. And performance would most likely be diminshed.Jared W. Drummond<br />jdrummon@vt.edu<br />1997 3.8 Firebird M5<br />-----------------------------------<br />*Flowmaster 80 Series Muffler* *SLP Cold Air Intake* *Zexel-Torsen LSD* *1-Piece DS* *Eibach Pro-Kit* *Removed MAF Screen* *Manual Fan Switch* *Mobil 1 Oils*<br />-----------------------------------<br />*Pioneer Premier DEH-920R Headunit* *Orion Cobalt 6 1/2\'s* *Sub Stealth Box w/ Alpine SWR-1021D* *Kenwood 728S Amp for Sub*
yup, and how is the coolant supposed to cool if it is constantly being flowed thru the radiator and not staying in it to cool off?
<blockquote>quote:</font><hr>it's really not recommended unless you're hardcore into racing <hr></blockquote>
heed the warning ;)1978 Formula 461 in progress of being built :rock:
2013 Ram 1500 Big Horn
94 comero 3.4
<blockquote>quote:</font><hr>yup, and how is the coolant supposed to cool if it is constantly being flowed thru the radiator and not staying in it to cool off?
<hr></blockquote>
The coolant doesn't have to stay in the radiator to cool it off. The function of the thermostat is more to get the car up to operating temp than to keep the water in the radiator to cool it off. The problem of no thermostat is more related to the pressure put on the radiator cap than flowing too fast. If you REALLY want to try and run your car without a thermostat, snip the "brackets" that hold the center section in and run the outside shell (what we do on our drag car). This works good because we have an electric water pump and fans, so the water get circulated all the way through for better cooling (while car is off). As others have said though, I definately wouldn't do this on the street or in colder weather as you'd be putting more wear on the motor trying to get it up to operating temp.
As far as the flowing too fast or not in the radiator long enough, think of it this way - Your tranny cooler is flowing CONSTANTLY and it does a great job of cooling the fluid. I'm open to constructive disagreement though...
RonI know - Camaro 67-02.. 2000 Camaro V6/A4 Black T-Tops<br />1969 Camaro 350/PG 12.69 @ 102.5 1966 Chevy II Wagon 283/PG Destined for NHRA stock eliminator.
ok, the tranny fluid is cooled by using the air flow thru the radiator & the collant in the radiator. It could still work, but wont be as effective. And the 700r-4, and newer trannies like to run hot.1978 Formula 461 in progress of being built :rock:
94 comero 3.4
by ssms5411Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...21 hours ago
Working on getting my 99 Camaro back in action. Long story short, got parked in the garage about 5 years ago (kids, career stuff ect.) trying to get her...3 weeks ago
