Yikes... last night I was driving south of Bloomington/Normal IL on I55, cruising at 80mph, and all of a sudden the Firebird just dies w/o warning. It's a 2002 with 49K miles on it. After 2 hours on the side of the road on a cold rainy night, today I find out it's going to be $1100 to replace this thing - $500 or so for the pump assembly and 6 hours of labor. Too bad I can't do it myself, but the car is 120 miles from home. Thank God I had a cellphone. By the time I add in towing, rental car for two days, and misc expenses, I think I'm looking at $1500 for this. Geez!
Fuel Pump died at 49K Miles
Re: Fuel Pump died at 49K Miles
You can EASILY fix it for ~$130 or not as easily, but still pretty easily fix it for the same amount
1. Trap Door Method = cut a U shaped hole in the back truck metal platform thing (right above gas tank), get a manual and follow the easy steps, takes 30-45min tops.
2. take off the exhaust, lower the gas tank etc
Get a manual, do it yourself
That mechanic who quoted you was on crack1999 Camaro Z/28
1973 Firebird Formula
that price sounds about right for a replacement, but yeah if you could get the car back to your place, i would really think about doing it yourself.
but dam man only 49k miles? mine went out at 130k
it's really only 1,100 not 1,500
with the price of a stock replacement fuelpump, and dropping the rear end to get to the fuel pump (the right way to do it) 1,100 is about right
i personally was quoted only 900 to do it
I think I'd find a friend that would bring a roll back, or get it towed home some how and fix it yourself! Even getting a Ryder trailer towing thing for a hitch and get a friend with a decent truck to pull it with.2000 Camaro 3.8 <a href=\"http://www.cardomain.com/ride/2040383\" target=\"_blank\">http://www.cardomain.com/ride/2040383</a>
I had the same thing happen at 40k miles. Fortunately, mine was covered by my extended warranty because the estimate was $1200.
The mechanic told me to not top off my fuel tank and not let it get below 1/4 tank because both could make the pump work too hard and fritz out. May or may not be related, but I don't take chances!
Good luck.
Yeah if it had died at home I would have just had it towed home and done the trapdoor thing. But it was like 120 miles from home. I had to be at a meeting the next morning. I didn't have time to mess with it. I'll just be paying on the credit card for a few months :o)2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
Does anyone know if there is a defect in the F-body fuel pumps because I see a lot of people on here having to replace their pump.
The reason I ask is many years ago I was told that running your fuel tank low is the #1 reason for fuel pump failure. So, I never run my tank low and I have never had a fuel pump go bad on any of the many cars that I have owned.
Do think think this holds truth or am I just lucky?
Originally posted by nascar24jdDoes anyone know if there is a defect in the F-body fuel pumps because I see a lot of people on here having to replace their pump.
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...3 days ago
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...6 days ago
by 187sharkHi all new to the community here. I have a 2014 RS 6 speed manual... and so about a year ago my tail lights got cracked and eventually the plastic housing...2 weeks ago
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...4 weeks ago
