yeah the fuel the pump is submerged in and the fuel flowing through it are supposed to cool the thing down. When you buy a pump for our cars you get the entire assembly not just a pump which is one of the reasons its' so expensive.
I keep hearing all these horror stories about how hard it is to change the pump or cutting holes in the floor. My roomate changed the pump in a 96 and the hardest part for him was dealing with the exhaust. The muffler was connected to the over axle pipe with a clamp that crimped the pipe and made it difficult to get off.
He did the whole thing with the car on the ground in an afternoon and that was with having to make a run to a buddies to pick up a hacksaw.
-Brad
2000 V-Star Custom 1100
:rock:
if you cut a hole in the tank, how do you stop gas fumes and **** from coming in??
also, once you cut the hole, does the fuel pump just simply pull out or what?
You do not cut a hole in the tank. If you use the access panel method you cut a hole in the floor of your rear hatch area in order to access the top of the tank.
Once you have accessed the tank the pump and assembly can be removed from the tank by twisting it and lifting it out.
If you do not want to use the access panel method you will need to drop the exhaust and drop the fuel tank in order to access the pump.
Yikes... last night I was driving south of Bloomington/Normal IL on I55, cruising at 80mph, and all of a sudden the Firebird just dies w/o warning. It's a 2002 with 49K miles on it. After 2 hours on the side of the road on a cold rainy night, today I find out it's going to be $1100 to replace this thing - $500 or so for the pump assembly and 6 hours of labor. Too bad I can't do it myself, but the car is 120 miles from home. Thank God I had a cellphone. By the time I add in towing, rental car for two days, and misc expenses, I think I'm looking at $1500 for this. Geez!
funny... i was on I-55 tonight on my way to ISU to visit friends when my alternator took a **** and i got stranded, good thing my mom got me a AAA membership
