so i have a 97 camaro 3800 series ii automatic and a 98 firebird 3800 series ii 5-speed.
i wanna put the camaro engine into the firebird. is it just a simple swap?
everything stays the same? what modifications need to be done?
the transmission is staying the same on the firebird.
Uhm.. I'm not being a smartass or anything but what is the point of swapping the same engine with the same engine? There's a reason you're doing this that you haven't mentioned right? I'm just curious.
Take some pictures of the engine bay in the 98 please. If it was produced late enough in 98, then it could have the same engine as the 99+ meaning that the intake manifold is defferent, as are a couple of connectors on sensors.
Representin' Team Red In The North
Red '96 Pontiac Firebird "Smokeshow" 3800, M5, Far From Stock!!
I have never seen a late build 98 with the straight tb, they all have had the angled tb and therefore a direct swap from a 97
