engine hesitates when warmed up - FirebirdV6.com/CamaroV6.com Message Board
  • engine hesitates when warmed up
    lets see... my mom has a 2000 3.8 automatic.
    we have changed the cat, the fuel filter, and the air filter. what happens is when the engine gets warmed up it hesitates really bad throughout the whole RPM range.
    now usually if this were a misfire you would geta blinking code for continuous misfire.. but it isnt doing this. sometimes when you drive... and then have to stop at a redlight. the car will die.
    what can cause these symptoms?
    96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view&current=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
    i woudl say fuel filter but you already changed that
    1996 Metalic Bule Camaro: no cat BORLA muffler 245-50-16 falken 502\'s descreened MAF 1pc driveshaft<br /><br /><br />soon to come: fixing that dagum Quarter Panel that i jacked up.<br /><br /><a href=\"http://www.geocities.com/heartland_heat_v6\" target=\"_blank\">Heartland Heat V6</a> &lt;----CO-FOUNDER<br /><br /><a href=\"http://www.dahleinsurance.com\" target=\"_blank\">NEED INSURANCE?</a>
      i need a list of things that it could be?
      could it be the o2 sensors or MAF sensor?
      this is ONLY when engine is warm. when you first start it in the morning.. NOTHING is wrong.. but about 15 min of driving it does this bad
        dirty injectors?
        check all your plug wires.
        i had the same problem and it turns out i had burnt up 2 of my wires. it didn't give me a SES light
        clean the tb and maf
        1968 Camaro SS 509 BB M4<br />1970 Mustang Mach 1 351W M4<br />1985 Mustang GT 302 M5<p>Me: Scratch your chin for me.<br />Jepe: $@&% you<p>dstrbdv6: if you live past forty i\'ll start going to church again
          Still trying to find oil leak
          3 days ago
          Getting some work done on my truck
