Another spark plug question - FirebirdV6.com/CamaroV6.com Message Board
  • Another spark plug question
    For those of you that have changed your own plugs, how in the world did you get the number 2 and 4 plugs switched, I can barely get a hand on #2 and I can hardly even see the #2 plug. This is all from underneath, did you guys go at it from above or both or magically or what????
    99 Camaro *SOLD* 8/27/03<br />03 Toyota Tacoma X-Tra cab, 5spd, TRD package
    used one of those wrenches that swivel (what are they called) and an extension. my dad was on top of the car and i was underneath the thing, we kinda told each other how to get to the thing
    Visit My F-Body Page
      you need an extension... and hopefully u do not have fat arms...
      the trick is to get the extension on the spark plug, and after that is in place attach the wrachet wrench and there you go....
      [ March 10, 2003: Message edited by: silicuda ]</p>
        well # 2 plug is right up front so I just go at it from the top it's the easiest plug of all... #4 however I go at from below with a regular open end wrench same with #6
        <b>Black 1996 Firebird</b><br /><b>Newest Edition: Harlan Window Switch</b><br />Nitrous Express Kit,ASCD big block hood, SLP Loudmouth, CATCO hi-flow cat, CAI, -Maf, LSD, Flameball Shifter<br /><b>Best N/A 1/4 in</b> 15.216 @ 89.82 <b>Best N2O 1/4 in</b> 14.352 @ 97.46 &lt;--w/clutch slippage<br /><a href=\"http://www.geocities.com/motorhead69/\" target=\"_blank\">My homepage</a><br /><b>AIM:</b>MotorHead75068 <b>YIM:</b>MotorHead69
          I forget the numbers already, but like the drive side center and rear plug were the only ones I did from under the car, cause thats where I started, they were really easy. =/
          97 Special Edition Bird , Short bus stlye special
            its a feel operation. i just used a 3/8" driver, short extension, and plug socket. for the ones that i could not get the torque wrench on, i just used the hand tight + whatever amount of turn (it was on the box) to compress the gasket. its an iron block so very little danger of crossthreading/stripping.
            there was a bit of cursing and swearing since the front suspension doesnt leave much room to get up in there.
