For those of you that have changed your own plugs, how in the world did you get the number 2 and 4 plugs switched, I can barely get a hand on #2 and I can hardly even see the #2 plug. This is all from underneath, did you guys go at it from above or both or magically or what????
Another spark plug question
used one of those wrenches that swivel (what are they called) and an extension. my dad was on top of the car and i was underneath the thing, we kinda told each other how to get to the thing
well # 2 plug is right up front so I just go at it from the top it's the easiest plug of all... #4 however I go at from below with a regular open end wrench same with #6<b>Black 1996 Firebird</b><br /><b>Newest Edition: Harlan Window Switch</b><br />Nitrous Express Kit,ASCD big block hood, SLP Loudmouth, CATCO hi-flow cat, CAI, -Maf, LSD, Flameball Shifter<br /><b>Best N/A 1/4 in</b> 15.216 @ 89.82 <b>Best N2O 1/4 in</b> 14.352 @ 97.46 <--w/clutch slippage<br /><a href=\"http://www.geocities.com/motorhead69/\" target=\"_blank\">My homepage</a><br /><b>AIM:</b>MotorHead75068 <b>YIM:</b>MotorHead69
its a feel operation. i just used a 3/8" driver, short extension, and plug socket. for the ones that i could not get the torque wrench on, i just used the hand tight + whatever amount of turn (it was on the box) to compress the gasket. its an iron block so very little danger of crossthreading/stripping.
there was a bit of cursing and swearing since the front suspension doesnt leave much room to get up in there.
