iginition coils - FirebirdV6.com/CamaroV6.com Message Board
iginition coils
  • iginition coils
    ok guys here is my problem, and just to let you know i have done a search on this subject and found nothing, well anyways about three moths ago or so i changed out all my ignition coils and everything started running fine. then about two weeks ago i went to start my car for the day and it just died. went back to autozone and they found out that one coil had gone bad, so i got another new one. well last night i was gonna go out and started up my car, everything was fine, went to back out of the parking spot and the car just died. today i plan on taking them to autozone again. if they find out that the ignition coil is bad again, is there anything that could be making these go bad that often? i have had my icm tested both times and both times it checked good. what could be causing the ignition coils to go bad?
    water seepage is my theory... the whole assembly (tray, ICM, and coil packs) is shaped like a bathtub and i feel like it collects inside there. normally the ICM will go out first so i'm wondering what method you used to test it. a continuance check won't show it because the circuit only breaks down under load. i'm sure you have heard to replace the coils all at once because when one goes down, all the others are thrown off.
      How many miles on the car? if its high, do you guys think it could be the alternator?
      Now, how badly do YOU want to see my brake lights?<br /><br />Pacesetter headers, 3 inch y pipe, high flow cat, magnaflow catback, many suspension mods, intake, built a4 with 3200 torque converter, 5 angle head job, dis 4, firewires, etc etc....
        If the ICM is not too much, and you have more than 100K, I woul dreplace it. Mine is do REAL soon. Also, how much were the autozone coils individually? If they are near $25 or $30 just get some accels. Thats what I did. Cars running great at 135000 miles! :D
          well i changed out all three three months ago and it still killed the other one. ok went to autozone to get it tested with them. im imagining that they put it on a load to test it. but i know they only test the coils with a volt meter. how much are accells and how much of a difference do you feel with them?
            nobody here has liked accels yet... the stockers are just fine but if you've got the aftermarket bug in your ear the MSDs are right in there and not that expensive either
              if one coil is bad the car can still start but will idle very bad,check the module or the crank shaft sensor......it is the crank shaft sensor that triggers the coils to spark
                I bought an autozone coil about 3 months ago. It was about 18-20 bucks
                \"this isn\'t flying...its falling...with style!\"<br /> -Buzz Lightyear<br /><br /><br /> 96 bright red firebird, T-tops, monsoon CD Flowmaster catback dual exhaust <br /><br /> <a href=\"http://members.cardomain.com/joyfellowship1\" target=\"_blank\">http://members.cardomain.com/joyfellowship1</a> <br /> <a href=\"http://www.joyfellowshipchurch.com\" target=\"_blank\">www.joyfellowshipchurch.com</a>
                  with the current GM corporate ignition, you really need to replace all the coils at once.
