I broke my header bolts in half. i need to drill new threads now. - FirebirdV6.com/CamaroV6.com Message Board
  • I broke my header bolts in half. i need to drill new threads now.
    not sure if its called header bolts or not. but its the 2 bolts on each side that you unbolt
    when you're unhooking your cat-converter and the rest of the exhaust.
    so on my 98 firebird. i had my air gun set too high or the bolts were just old...
    and snapped both bolts in half. i got the exhaust off.
    but i have to put the exhaust back on.. and the 2 bolts that broke are stuck
    in the part that screwed in. hard to explain.
    so i need to grind the bolts off with those things u use to put a threaded hole onto something.
    i dont know what they're called but i'm gonna borrow some.
    it looks like a drill bit but has threads on it. so u can drill a hole with threads
    and then screw a bolt into it. does anyone know what size i'll need?
    i got the 2 extra bolts already. just gotta drill the new hole.
    Re: I broke my header bolts in half. i need to drill new threads now.
    http://www.bimmerboard.com/forums/posts/17946
    This should give you an idea what you need to solve your problem.
    Black \'96 RS Camaro, 3.8 V6 Series II, M5, Stock 200 HP, 204K miles! Stock \'91 Firebird 3.1 V6 automatic w/ overdrive. 266,400 miles on it. \'83 Pontiac Trans Am,305 LG4, Cowl Induction,Borg Warner 5 Speed,T-Tops,Gale Banks Exhaust System:$800 obo
      i have some of those. i dont think mine will come out though. they're gonna have to be drilled out and its gonna ruin the threads.
      i think i might just drill 2 new holes.
        If you drill them out you may be able to use nuts and bolts instead of trying to tap the new holes.
        Brian
