Anyone ever had problems with their Ignition module? - FirebirdV6.com/CamaroV6.com Message Board
  • Anyone ever had problems with their Ignition module?
    On the way to work it kinda started backfiring under high RPMS. Then it it started not starting had no spark. Heard all the 3.1 2.8 3.4 and 3.8 had this problem because they get too hot from the engine, so i changed it today while i was at work in 30 mins..
    New:04 GMC Sierra 1500 RCLB 4x4 5.3 GU80 3.73\'s.<br />Truck pics<br />Mods<br />Go fast: Panel K&N filter and soon SS truck catback.<br />Appearance: Stull Billet grill,Weston Chrome step tubes,Rhino Chrome hitch step,ARE painted fiberglass cover,Silver star lighting.
    No one?
      I had a problem with a coil pack, but it died b/c it overloaded.
      Ben<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
        yes, i have had to replace mine twice. i always post when ignition issues come up.
        the coil pack/ icm assembly is fundamentally flawed. it likes to collect water but thankfully it is easy to get to... but that doesn't make it any less of a PITA.
          3.4's suck balls when it comes to ignition BS I've changed each of the coils 2 times, I think i'll try to end this madness and just get msd ignition maybe (crosses fingers) it will work.
          ---Niño---<br /><i>95\' silver 5 spd</i>
            Yea it was a hot *** humid day.
            The Module i got has a Lifetime warrenty from my work [img]smile.gif[/img]
            But we also carry delco Coils for around 30 a coil i wonder if i should ho ahead and replace the coils too..
              My ignition module seemed to be going out so I was going to get a new one. Then I found out how much a new one was going to run. I took the module off and found a lot of corrosion build up on the bottom of the unit. I cleaned off the corrosion and applied a coat of spark plug lube to the bottom and that seemed to fix my problem. Maybe it will work for you.
                It was only 69 with my 20% discount..
                  I just had to replace my Ignition Module this weekend. My car was running real rough. I went out and found one for my car but it cost me $222. That was an expense I was not looking for right after getting my Clutch put in and rearend leak fixed.
                  98 Silver Camaro V6<br />15.238 @91.74 w/ 2.288 60\'<br />Mods: K&N, FTRA, Pacesetter Headers, Spec 3 Clutch, 160 Thermo, TSP Rumbler, 3\" Catco, Whisper Lid, 3.42\'s w/LSD, Aluminum DS, Man Fan Switch<br /><br /> <a href=\"http://www.cardomain
                    http://cgi.ebay.com/ebaymotors/ws/eB...909250258&rd=1 better get up on this deal 6 hours left 25$ brand new
                    1995 Camaro 3.4 M5 - Project<br />1998 Camaro 3.8 A4 - Daily<br />Aim:V6OnSpeed<br /> <a href=\"http://www.cardomain.com/memberpage/576233/1\" target=\"_blank\">http://www.cardomain.com/memberpage/576233/1</a>
                      Sucks for you 3.8 people..
                        never had a problem with gettin spark ever except when my plugs/wires needed changed
                        • 187shark
                          by 187shark
