not the fuse and i have no cruise control, ne suggestions of the problem?
cruise control gone
could be a problem in the switch, could be a problem with the clutch pedal sensor, only two things I can think of...
g2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
yea i got the same problem. it will go into cruise control for like.. 10 seconds..then just turnoff..96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view¤t=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
Originally posted by Tyler:
yea i got the same problem. it will go into cruise control for like.. 10 seconds..then just turnoff..www.turbov6camaro.com
1997 3800 Series II Camaro
Originally posted by Chet Mo and the Camaro:
i have an auto!!www.turbov6camaro.com
typically the problem is in the steering column or the stalk itself. First thing is check to make sure you have good vaccum to the crusie control then it becomes an electrical issue. If you want to scan your codes go to autozone and ask to borrow the odb 2 code scanner and tell em you have a gm.-Brad
2000 V-Star Custom 1100
:rock:
Have you replaced your rear end (i.e. change the gear ratio)? If so, untill you re-program the PCM, the cruise will not work.2001 Firebird 3.8L V6 M5,<br />It once had....<br />NX Nitrous Wet Kit, ZZP X-P Hot Cam, <br />3.42 LSD, Pacesetter Headers, <br />36# Injectors, HP Tuners<br />322 RWHP, 379 RWTQ<br />13.596 @ 102.56 w/100 shot
I just discovered the same problem today on my 99 while going on a road trip. I haven't checked the fuse yet, but I suspect it's fine.
Where do I check the vacuum, at the tranny, or at the motor? I'm not used to late-model v-6's just yet. [img]graemlins/naughty.gif[/img]
[ August 21, 2005, 12:50 AM: Message edited by: Rabid Dog ]<b>99 Pewter Metallic Camaro</b><br />SLP Ultra-Z Hood, Shaved Antenna, !mouldings, Chrome Halos, Filled Factory Grill, Y2K 18 R 19 F, SLP Whisper Lid, (functional w/ Hood), FlowMaster American Thunder C.B, QA1 Coilovers, Kuhmo Tires.
why would i have my foot on the clutch when im in cruise control?96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view¤t=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
my car somtimes the crusie will work just fine and then going dow nthe highway it just stops so i push in the clutch turn the car off and restart it and then it works again[img]graemlins/stickpoke.gif[/img] [img]graemlins/twak.gif[/img] [img]graemlins/rofl.gif[/img]
figure that one outwww.turbov6camaro.com
You reset the computer by shutting it off DUH! I had the same problem with my ABS light coming on.FTRA kit, Whisper Lid, free ram air mod, Richmond 3.73 gears, Dynomax Catback, Poly Tranny mount, Vette Wheels, Expensive Audio equipment :). HID headlight Kit, Billet Grille, Billet Antenna, Eurotails, Carsound Cat
i would have the cruise on and it shut off and stop working.... only way to do it was to restset it buy shutting off the carwww.turbov6camaro.com
