OK. Here's the deal... When driving on the highway, I use cruise control. It works fine. Then, when I turn off the highway, and the cruise control has been disengaged by hitting the brakes, the gas pedal seems stiffer than usual. The car still drives fine, but the pedal seems stiff. When the pedal is stiff, if I give it about 3/4 gas, the pedal makes a clunking noise, then goes back to its normal stiffness. Has anyone experienced this? If so, what was the cause?
Possible problem with Cruise Control
It drives ok, and the cruise "grabs" and "lets go" as it should it's just a little wierd having the clunking noise after hitting the gas pedal. It's almost like a vacuum problem. The cruise control runs on vacuum, right?
[ March 11, 2003: Message edited by: sped214 ]</p>1997 Y87 Camaro with a motor and some stuff.
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...9 hours ago
