Proportioning Valve help - FirebirdV6.com/CamaroV6.com Message Board
  • Proportioning Valve help
    Okay, I'm getting ready to do my rear end swap. I have a 97 and am getting a rear out of a 95 Z28. I want to go ahead and order a proportioning valve incase I need it. I can't seem to find the part anywhere. I would just order a proportioning valve for a 95 Z28 correct?
    I looked on a couple websites and one I just couldn't find anything for that and another said there was no such part for 95 z28. I haven't called a dealer yet, but am figuring that it will be expensive as hell if I get one from the dealer.
    <a href=\"http://www.cardomain.com/ride/2093533\" target=\"_blank\">CarDomain Page</a>
    Last I checked, it should be the same part number.
    At least for '97 it was.
    Make sure you have the right number of channels for your ABS also.
    1997 Cayenne Red Metallic Camaro<br />3.8 V6 M5<br />SLP Cold Air Intake<br />Ceramic Coated Pacesetter Headers <br />Flowmaster American Thunder Catback<br />Full 3.42 & Disc Break Rear End Swap
      What do you mean by your last statement? I am having a buddy of my stepdads do the swap. He's a mechanic. I guess he will know what you mean though. I was told to make sure I get that E brake cable off the z28. That was about the only thing I would need though.
        Propotioning valves are the same.
        Make sure if your car doesn't have traction control, that the donor car doesn't either. I made the mistake of getting a rear (well, contemporary corvette sent me the worng part and I couldnt wait the extra downtime to return it) from a car with traction control, I have been antilock brake-less since then.
        97 Camaro<br />160* thermostat, z28 shock/springs, 3\" Magnaflow cat, 3\" Magnaflow catback, LT1 disc/limslip/3.42 rear, SLP CAI<br /> <a href=\"http://www.cardomain.com/memberpage/609893\" target=\"_blank\">http://www.cardomain.com/memberpage/609893</a>
          Mine doesn't have traction control. Not sure about the car the rear end is coming out of though. I will try to find out. thanks
