terrible gas mileage - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    Re: terrible gas mileage
    This past summer I recall my gas mileage improving much better after my EGR valve swap, try that IF you have any SES lights or codes stored.
    I also noticed a tiny decrease in overall MPG myself, turned out to be tire pressures were not equal all around. Colder temperatures will reveal your true tire pressures when you check in the morning. Best to check tires when cold overnight.
    We can expect more topics such as this as fuel refineries will distribute winter fuel blends across the nation and charge us higher for that kind of quality fuel. Winter blends may drop your MPG.
    My .02 cents
    Black \'96 RS Camaro, 3.8 V6 Series II, M5, Stock 200 HP, 204K miles! Stock \'91 Firebird 3.1 V6 automatic w/ overdrive. 266,400 miles on it. \'83 Pontiac Trans Am,305 LG4, Cowl Induction,Borg Warner 5 Speed,T-Tops,Gale Banks Exhaust System:$800 obo
    • #17
      unplug ur computer for a couple seconds from the car. As funny as it sounds i went from gettin 16~17mpg to 21mpg, and i didnt change anything else. I just was installing my amp wires.... give it a try
      • #18
        instead of unplugging the computer just unhook the batter. All that does is reset the computer and it relearns everything. It probably worked for you because your tuning was off perhaps... but I don't think thats gonna fix his problem.
        Welcome future UK stars... Darius Miller, Deandre Liggins, Kevin Galloway, Josh Harrellson
        • #19
          oddly enough, i filled up the other day and im getting really good ga mileage.. no idea why, i didnt do anything to it.
          1999 v6 Camaro M5
          Automatic to Manual converted
          Pacesetter Headers, 2.5" Custom True Duals with X-Pipe and Magnaflow Bullet Muffers,
          !cat, Intake, 3.42's with LSD, MSD Wires, Drilled/Slotted Rotors, Hurst Short Shifter, Tuned PCM
          • #20
            I'd say look at the cat, I've seen them so bad the car wouldn't get up to 55...
            Depending on where you live you may be able to get a backwoods 'test pipe' you can put on to check if it's the cat. A "test pipe" is just a blank piece of pipe with the fittings pre-welded on it to bolt in place of your cat. If it fixes it it is up to you what you do then...
            Oh, the ticking noise... only at idle? Maybe gets worse when the oil is hot? Is it better after a fresh oil change? Sounds like lifters ticking. Why? Because you have low oil pressure at idle if your bearings are worn. I don't really trust the OEM guages, they are just not real precise. Does that mean your engine is gone? Not really, I've seen engines that the oil pressure light would come on at every red light go and run 2-3 yrs longer.
            2002 Navy Blue Metallic Blue Firebird A4
            Pure stock (Hey, just bought it 11/07)
            • #21
              I had the same ticking problem
              I didn't let it continue long enough to see if it effected my gas mileage, but it was an easy fix, I just bought a thing of Marvel magical additive or something like that, it comes in a red 1 quart bottle for like 7 dollars at any auto store
              follow the dirrections for cleanning the internal engine, If I remember right you add it to the oil and run it for like 100 miles then change the oil
              it cleared the ticking right up
              the ticking was probably caused by a piece of carbon build up making a lifter stick, once you accelerate the lifter is under enough force so that it won't stick, seafoaming could have even knocked the carbon lose from somewhere else and it just made its way to the lifter
              K&N air filter, Whisper air lid, magnaflow LT1 cat back, and magnaflow high flow cat, pacesetter headers, silverstars<br /><br />more to come soon<br />but for now im out of money
              • 187shark
                by 187shark
