I know some of you have this problem.. the rough starts in the morning where it chugs almost as if theres a vacuum leak. I recently changed my battery to chassis and engine block to chassis ground wires to larger 4 guage wires. Apparently that fixed the chug it does in the morning. I'm not positive on it yet but just wondering if anyone who has upgraded their ground wires has or still has that startup problem. It woulda been nice to know awhile ago how to fix this so if it helps anyone I'm sure they'd appreciate it :) Just gotta absolutely verify it first.
Rough starts in the morning fix maybe?
Re: Rough starts in the morning fix maybe?
Originally posted by jagerskullsi got the same stupid problem im hoping its nothing to serious
TEAM C6V6
Originally posted by Black 98 JoeI had rough idle in the morning on my car. It was the fuel pressure regulator. Fuel was leaking from the FPR back through the vacuum line, causing the car to run rich. Easy way to check this is to pull the FPR vacuum line and check for fuel.
TEAM C6V6
whats the car specs?? how long does the "chuggin" last? does the engine run like shiz or just rough, like its warming up? winter weather does have an effect on our cast iron blocks.Heady Navy Blue Metalic<br />Heady Catback Flowmasters<br />Heady Bilstien HDs, PAnhard rod, LCAs,SFCs<br />NGK\'s and MSD Wires, K&N flowin + Smooth Bellow<br />Y87 3800 GT Performance.<br />I love the way this car makes turns!<br /><br />1989 black Camoaro RS. R.I.P.
Htpp3 "tune", flowmaster, gutted cat, whisper airlid.. 3.8 02 engine.
It completely stopped doing it. When it did do it, it was almost as if it was gonna stall out. I think it might have once, I can't remember. But it lasted up to like 30 seconds almost, smoothed out and didn't do it again till I turned it off, it cooled down and sat for awhile.. say like a little over 4 hours to cool off. It's a little confusing cause if its a temp issue then I wouldn't entirely think the electrical would have a whole hell of a lot to do with it. Temp might have been just a misleading factor when the battery was really just losing a bit of power after sitting for awhile.
TEAM C6V6
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...4 hours ago
