how bad is water in oil? - FirebirdV6.com/CamaroV6.com Message Board
  • how bad is water in oil?
    if i have an oil leak and water slowly gets in somehow and if i drive the car on a regular basis and change the oil regularly, how bad could it get? i mean winter is coming, and i always find crud in the oil cap, showing signs of water. am i screwed? i cant affor to fix it. rear main seal is leaking i think, dont know for sure but oil leaks all over the y pipe.
    can anyone give me a ball park range they had to fix a leak like this?
    Re: how bad is water in oil?
    Sounds like head gaskets.
    It is probably not a good idea to drive it.
    Im not sure on the cost depends if you do it you self or have a shop do it.
    -Y87
    Lid,K&N Filter,PaceSetter Headers,Magnaflow Cat 2.5in S-pipe,Flomaster :(,3.42 LSD
      rear main is about $350 to have done, but a leaking rear main wouldn't get water in your oil. if you have the time and know how, you can do the head gaskets yourself, but it is pretty involved. But it sounds like that's the problem to me too.
      1996 Chevrolet Camaro
      1995 Buick Park Avenue Ultra
      --Appearance Moderator--
        I had the rear main done a few months ago and it was around 400.
        Welcome future UK stars... Darius Miller, Deandre Liggins, Kevin Galloway, Josh Harrellson
          water/oil is either lower intake manifold leak, or a head gasket
            or a cracked block
              a lower intake leak would be a job to take off the intake throttle body and valve covers to fix? it would be under the heads then right?
                I had the whole dissappearing coolant and the 'mayonaise' in the oil fill neck / oil cap. Ended up being the lower intake gaskets for me, since then no more issues :)
                If it is an upper intake leak you would need to get down to this point:
                But at that point you might as well change the lower intake gaskets, which is just that one more part coming off. I just did this a couple weeks ago, took about a day, I took two though working only a few hours each time. Very do-able. You can do it, just take some time, set aside two days just in case, and read up a little on it. All together my bill from Autozone was under $100 in parts (upper and lower gasket, some rtv, paint)
                  one tips if you do this yourself. get little zip lock bags and label each bag of nuts, bolts, screw or what ever. what is it, and where it came from. alot of saved time later. works wonders for me!
                  WAWA-A-HOLIC
                    tip I have... just go buy new lower intake bolts... one snapped on me, (towards the rear of course) leading me to have to pull the head. they are not easy to find off the shelf anywhere.
                    and a few of my other ones I did not trust replacing...
                    Also if you do do a headgasket, our headbolts need to be replaced. Most autopoarts places carry them.
                      So if Oil is leaking all over the y-pipe, that a head gasket leak?
                      i have been looking under the car everytime when i change to oil, do other things ect... but i cant pin point the leak cuz there is so much shiz in the way. i turn on the car and it slowly drips around the oil pan and stuff. but it doesnt seem to be coming out of the oil pan.
                        I would say rear main... when you drive the car its blowing onto the exhaust and when its running at idle, its just leaking down the side of the oil pan.
                          rear main usually will leak oil on to y-pipe...
                          also forgot, if you pull the lower intake, replace the plastic coolant elbows. They will break when you pull it.
                            Thanks for the tips guys. now trying to figure out my game plan.
                              Change the valve cover gaskets before you do the rear main. Oil will run down the back of the motor from leaking valve covers and get on the exhaust.
                              Brian
