is it possible???? - FirebirdV6.com/CamaroV6.com Message Board
is it possible????
  • is it possible????
    i want to block the hose that goes to the canister,,is that possible??
    i have a feeling that the canister is bad....thanx for your help in advance.
    Re: is it possible????
    huh??
    TEAM C6V6
      lol, my only guess is you are talking egr
        Originally posted by UDLOSE98
        lol, my ony guess is you are talking egr
        Yeah that's what I was thinking but I try not to make assumptions.. I learned my lesson with assumptions awhile ago. If it is your EGR valve then yeah, you can get block off plates somewhere but then you either gotta tune it out or get a sim.
        TEAM C6V6
          Originally posted by Blizzard242
          huh??
          hey yo!, im talking about the hose that goes along with the fuel hoses back to the tank. get it?? man english is not my language ,thats why it is hard for me to explain.
            at least everybody knows how to speak "internet" language.... omg rofl ttyl lollerskates, syrup on my rofls with a side of blueberry pwncakes!
              hahaha
                Hahahahhahahahaa!
                TEAM C6V6
                  If it has to do with the fuel system.. ugh, Figure out it's purpose. Then how to fix/replace it. Don't just block it off. ****, my alternator isn't working right in my other car.. I guess I'll just get rid of it. hah.. oh yeah.. that also reminds me of a lot of girls I know.. If they here something wrong with their engine area they just turn up their stereo so they can't hear it. Seriously though, figure out your problem don't try to ignore it.
                  TEAM C6V6
                    he is talking about his evap canister yes you can clamp off the lines disconnect them or just unplug the purge solinoid beware this will set a code(turn on the check engine light) on ob2 cars there is no performance loss from doing this it takes the air pressure(and fuel vapors)that build in the tank from running and the heat of the day and releases them into the engine under cruse conditions to be burnt
                      sorry didnt see your screen name just disconnect your purge solinoid at the intake manifold or disconnect to hose and block of the engine side nbd on a 3.4 obd1
                      bye the way love you screen name
                        finally a smart person,,,thanx auto 666 and your screen name makes me nerves,since it is a devils # anyway,,,,,,i feel a strong smell of fuel in the car rearend,and its not the tank since it holds the pressure very well,so i guessed it is the evap canister,,,so it wont hurt the car if i block the hose until i get it fixed??? if i dont unplug it it wont cause a code???? performance loss???? bad fuel milage??? thanx
                          no it should not set a code and no performance loss, not enough milage difference to even notice.
                          and dont worry about my screen name im a nice guy most of the time :) lol
                            this is the fastest respond ever,,,thanx my friend,,try auto777,,:)
                              lol no problem
                              • Andy H
                                Transmission removal help!!
                                by Andy H
                              • 2.8 Bird
                                Abs inop
                                by 2.8 Bird
                              • fishin
                                by fishin
