is it possible???? - FirebirdV6.com/CamaroV6.com Message Board
is it possible????
  • #16
    Re: is it possible????
    Originally posted by auto666
    he is talking about his evap canister yes you can clamp off the lines disconnect them or just unplug the purge solinoid beware this will set a code(turn on the check engine light) on ob2 cars there is no performance loss from doing this it takes the air pressure(and fuel vapors)that build in the tank from running and the heat of the day and releases them into the engine under cruse conditions to be burnt
    Hey I learned somethin. :banana:
    TEAM C6V6
    • Andy H
      Transmission removal help!!
      by Andy H
    • 2.8 Bird
      Abs inop
      by 2.8 Bird
    • fishin
      by fishin
