1994 a4 firebird is so slow that it can't make enought power, at WOT, to make it to the shift point. If I let off the gas a hair I can feel the power pickup and then it shifts. I have taken the car to a dealership and 2 other different transmission shops and they all say its an engine problem. Where do I start?
Fuel pressure is 43 psi idle / 50 psi WOT.
New plugs and wires
New intake gaskets
New fuel filter
I was at a shop today and they took the fuel line off the filter and fuel sprayed out the back of the car about 8-10 feet. The shop said that wasn't normal and that I had a backup in the lines somewhere, but If that was the case how could I have 43psi idle / 50 psi WOT?
They also were looking around the fuel tank area and they noticed some black lines that looked out of place. They said that it looked as if someone had the fuel tank out before. So basicly I have no idea how to even start to fix this. No shop can even figure it out.
Only codes are:
EGR SOLINOID #2
EGR SOLINOID #3
I tried replacing the EGR with a new one and one from a junk yard to no avail. Also I did notice that there was something on the scantool called a quad driver. 3 of the 4 said bad.
New plugs and wires
New intake gaskets
New fuel filter
Only codes are:
EGR SOLINOID #2
EGR SOLINOID #3
