Serious lack of power! Need Expert. - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    Re: Serious lack of power! Need Expert.
    is your check engine light always on??
    • #17
      nope. It only comes on once and a while and its for the egr.
      • #18
        have you fixed the egr?
        have you pulled the plugs? What kind of shape were they in? Black and wet? covered in oil? Charred looking? White/orange? Do you have a misfire at any time, or any strange noises? There are lots of things that could be causing a constant loss of power.. the more info you can give, the better..
        • #19
          if it was the timing chain it wouldnt run that bad.. unless it jumped multiple times.
          check your cam timing if you really think that is the problem. the dots should line up, if they dont, then you know it jumped..
          a bad injector will give you a misfire code.. or even bad injector codes (if they have them)
          • #20
            Have you checked the TPS? Maybe it's dead above 90% or so causing the PCM to think your off the gas?
            Brian
            • Andy H
              Transmission removal help!!
              by Andy H
            • 2.8 Bird
              Abs inop
              by 2.8 Bird
