man,,i want to buy an msd or another high performance coil,,,they say that they do 40.000 volts,,,they do that power onstock modules or you must use like an msd dis box to reach that voltage???
coil vs coil
Re: coil vs coil
Originally posted by vanbibberdont waste your money. the stock ones are just fine.2000 3.8L Camaro A4 Pewter Y87<br />K&N Filter, SLP Ram Air kit, Eibach Pro Kit, Flowmaster 80 series, Silverstars, NGK plugs and MSD Super Conductor Wires, Electric Water Pump
Re: coil vs coil
I've ran stock with my old powerdyne supercharger setup with no problems, and I also run stock with my 125 wet shot of nitrous with no problems. I would stick with stock.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: coil vs coil
I am no electrician so I have no idea, touch them with the car on and find out :)
I could care less what voltage they do as long as they get the job done really
Re: coil vs coil
i would imagine that they put out something close to the rated voltage, even with the stock module. The ignition box seems to be more for the multiple spark than anything, and of course some adjustments (course, you only get multiple sparks at lower RPM's... )Phill<br /><br />95 camaro... need money for turbo project... <br />94 S10 Blazer - winter beater - infinity system to be installed soon<br /><br />\"The man who says it cant be done should not interrupt the man doing it...\"
Re: coil vs coil
Originally posted by camaroman1181i would imagine that they put out something close to the rated voltage, even with the stock module. The ignition box seems to be more for the multiple spark than anything, and of course some adjustments (course, you only get multiple sparks at lower RPM's... )
Re: coil vs coil
Originally posted by 3.4orNothingwhy dont you put your pipi in it and find out for yourself??:)Dave:
00 Supercharged Camaro - RIP
97 Turbo Camaro - Sold
