coil vs coil - FirebirdV6.com/CamaroV6.com Message Board
coil vs coil
  • #16
    Re: coil vs coil
    Originally posted by 3.4orNothing
    why dont you put your pipi in it and find out for yourself??:)
    I am not the one curious about it ;)
    http://www.bowtiev6.com/
    • #17
      Re: coil vs coil
      the stock ones are 45k volts. the MSDs are at a much higher amperage though...but they still only help with a dis-4 box.
      • #18
        Re: coil vs coil
        thanx for laughing guys,,,,,,,,haha:) in my country pipi means small penis,btw.(pls dont ban me)
        • #19
          Re: coil vs coil
          if i did not hear wrong,,,stock ones are 25.000
          • #20
            Re: coil vs coil
            stock ones are $25 lol...WAIT!!!!! if you knew why the hell were you asking...
            • #21
              Re: coil vs coil
              he is saying 25k volts, not 25 dollars
              • #22
                Re: coil vs coil
                i know...but 25k volts isn't even enough to light a fart...
                • #23
                  Re: coil vs coil
                  as soon you learn how to read,we will talk
                  • #24
                    Re: coil vs coil
                    hey 97rs4life ! sorry about the pipi thing.
                    • #25
                      Re: coil vs coil
                      I know what he was saying...I was poking fun. the standard coils are 45k volts
                      • #26
                        Re: coil vs coil
                        there's a lot more to a coil than voltage
                        • #27
                          Re: coil vs coil
                          ohhh okkk..... but,as far as i know standarts aren`t 45k volts
                          • Andy H
                            Transmission removal help!!
                            by Andy H
                          • 2.8 Bird
                            Abs inop
                            by 2.8 Bird
                          • fishin
                            by fishin
