I need to R/R my oil pan gasket. The GM tech manual doesn't say to use any RTV or anything of the sort. When I purchased the new gasket from the GM dealership, the parts guy said that on the computer there was a note to USE with RTV. The gasket has a raised orange rubber seal. Not sure what do do.
To use RTV or not to use RTV, that is the question
Re: To use RTV or not to use RTV, that is the question
I would put a thin layer of RTV on the pan, let it tack up, then drop/align the gasket on the pan.FirebirdV6.com/CamaroV6.com Administrator
Stupid is rewarded with the ban button.
Official Avatar Nazi according to Meatyshells :D
Oil Pan Installation
1. Apply a continuous bead 6.35 mm (0.25 in) thick of RTV sealer GM P/N 12378521 (Canadian P/N 88901148) to the topside of the new gasket. Apply the RTV sealant directly over the gaskets sealing bead.
2. Install the NEW oil pan gasket onto the engine.
3. Apply a continuous bead 6.35 mm (0.25 in) thick of RTV sealer GM P/N 12378521 (Canadian P/N 88901148) to the bottom side of the new gasket. Apply the RTV sealant directly over the gaskets sealing bead.
4. Install the oil pan.
5. Clean the oil pan bolts of all debris.
6. Apply one drop of GM P/N 12345382 (Canadian P/N 10953489) to each bolt.
7. Install the oil pan bolts.
Tighten
Tighten the oil pan bolts to 14 N·m (125 lb in).
Install the oil level sensor.
Tighten
Tighten the oil level sensor to 20 N·m (15 lb ft).
this is a step by step from gm96 camaro auto base model<br />slp cai<br />pacesetter headers<br />flowmaster catback<br />35th anniversary ss wheels<br />richmond 3.73<br />98+ ss spoiler<br />hypertech 160 degree thermostat<br />transgo shift kit
