Bosch oil filter - FirebirdV6.com/CamaroV6.com Message Board
Bosch oil filter
  • Bosch oil filter
    Changed my oil today and instead of using the Bosch 3331 filter I used a bigger filter Bosch 3430, its about 3 to 4 inches longer. For the people that use Bosch oil filters, I didn't know if anyone knew Bosch had a bigger oil filter, so I thought I would share.
    Re: Bosch oil filter
    k&n gold class also makes filters that are a few inches bigger but still fit, i know cuz they gave me the wrong filter one time and it cost a few bucks more, does a bigger oil filter help at all?
      Yes, the more filter surface area the better.
      The standard filter is a AC Delco PF47. The longer PF52 will also work, or any cross-reference PF52 filter will work.
      I use a Mobil 1 M1-201 (PF52), which from all the studies I have read is the best.
      Raven
        is that mobil filter a bigger one as well?
          you wouldnt happen to know the part # would ya? Im scared to use bosch, i had a bosch spark plug MELT in the head of my honda :mad: it was only 5K old too....
            Yes,
            and you need to reduce the size of your sig.
            Raven
              i've been told to stay away from bosch..... i don't know the part # but i imagiine its just the same filter but for the lt1 maybe?
                more area for filtration equals better oil out cleaner--> circulation
                  Does anyone know if the PF52 or equivalent filter fits on a 3.4? I would think there would be room as its just an inch or two longer.
                    I thought the 3.4 already took the longer filter PF-52, my gf's '92 with a 3.1 specs it. I just buy 2 when it's oil change time.
                    2001 Pewter Firebird Y87, M5
                    Go Sabres!
                      yea they are interchangeable. And no, they come with the same size filter that 3.8s do
                      Car expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
                      • Andy H
                        Transmission removal help!!
                        by Andy H
                      • 2.8 Bird
                        Abs inop
                        by 2.8 Bird
                      • fishin
                        by fishin
