Hey guys Im having a small problem with my defroster. Ive noticed as of late when I turn the def. on it will only stay on for about 2 minutes then it wont let me turn it back on for a few more minutes. I know when you turn it on it usually stays on for about 10 minutes give or take at a time. Could this be due to a bad fuse or another problem?
Defroster problem!!!
01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
www.vaperz.com
Tags: None
Re: Defroster problem!!!
It's just the lovely f-body defroster. It's the safety system of it. Once it warms up to a certain point, it will shut off and goes into lockdown for a few minutes before it will proceed to let you turn it back on.
Yea, the safety feature is pretty lame. I always hated it, because I would seriously need for it to defrost fully sometimes. I got so tired of it, I pretty much just forgot about the defroster all together and just let it defrost on its own.
My defrost for the windshield is all that works. All the air regardless if is set to vent comes out the defrost vent and by your feet. The rear defrost button does not light up when pressed, nor does anything seem to come off the rear glass. Suggestions?
Originally posted by IICODECllMy defrost for the windshield is all that works. All the air regardless if is set to vent comes out the defrost vent and by your feet. The rear defrost button does not light up when pressed, nor does anything seem to come off the rear glass. Suggestions?
I never new it had a safety feature on it. I guess that would explain it beig on for jsut a short period of time.01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
www.vaperz.com
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...4 days ago
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...4 weeks ago
