ignition no voltage wiring help please - FirebirdV6.com/CamaroV6.com Message Board
  • ignition no voltage wiring help please
    My car cranks but does not start. I checked all fuses and relays. The ignition control doesn't get 12v from the wiring harness... it ususally gets less than 1 even when cranking. Anyone know whats wrong? I'm assuming there is a wiring problem can somebody please help me rewire the ignition? The relay has an always hot red and then 2 pinks which are hot when the key is in "on", and a thin black wire. All three thick wires have 12 volts when the key is in "on" but the icu harness does not get 12 volts.
    see if your lacking spark and or fuel.
      it's spark that's why i checked the icu voltage and it's not 12 volts
        What pin are you chekcing for ign voltage?
          the pink wire, on the far right i believe
            did yuu check the ign fuse with the key on?
              it was the stupid egr ctrl fuse
              the wiring diagram doesn't even show that fuse in the circuit thanks wiring diagram
