Like the title says, i can't get my key out of the ignition. I can cycle trhough every gear without even engagign the button (a4). The transmission is shifting fine, but I sitll have a feeling something is wrong with it for this simple reason. Anyoen ahve any ideas? I don't even have to have the brake pressed in to shift between all the gears. I let my little brother drive it yesterday and now this occurs.
can't remove key from ignition, think it has somethign to do with park
Re: can't remove key from ignition, think it has somethign to do with park
btw, i did search and this was the only auto one I could find:
http://forum.camarov6.com/showthread...ght=remove+keyCar expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
sounds like the lock cylinder is sticking.
Follow me!
Or this
so i guess i have to take the console off and lube it :( shoudl I use wd-40?Car expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
Roger I'll be up at my dad's on sunday, you think you might wanna meet up? Not to do this, but to just hang outCar expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
Shift lock release or something like that.
There is a switch/sensor that tells your car when it is in park. If that switch/sensor isn't tripped it won't let the key out of the ignition. My grand prix does the same thing. I just lock the door with the key in the ignition and use the remote to get it :D
Originally posted by NachiusShift lock release or something like that.
There is a switch/sensor that tells your car when it is in park. If that switch/sensor isn't tripped it won't let the key out of the ignition. My grand prix does the same thing. I just lock the door with the key in the ignition and use the remote to get it :DCar expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
btw, roger and shane, why dont you guys ever get on aim anymore? I guess I can't really say anything thoguh seeing as I never got on until school started back up lolCar expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
Originally posted by v6mOtOrhEAdftOpRoger I'll be up at my dad's on sunday, you think you might wanna meet up? Not to do this, but to just hang out
when im waking up for work, she's just falling asleep. sucks.
ill find out her schedule and let ya know when im free though! its been a while, maybe i can get some buddies off thier asses and we can have a mini fbody meet :D
Follow me!
Or this
btw, im on aim everynow and then, damn thing works when it wants to so i get pissed and dont use it for a while until i cool down and dont want to kill aim.
Follow me!
Or this
yea lol I know what you mean. I've ben trying tog et back on it for the past 15 minutes. For some reason it jsut doesn't want to workCar expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
I had the exact same thing happen to me. It got stuck and wouldn't come out. What I ended up doing was turn the key forward without starting it up, but enough to turn on the electronics, move it through all the gears, then put it in neutral, let it roll back a bit, put it in park, then take the key out. What it's doing is not turning all the way back. All I had to do was fiddle with it for a few minutes to get it out. No big deal. Hasn't done it since.Originally posted by LETZRIDEI've never touched a rear end before
Also try taking it out in neutral. :P then work from there. You said you think it has something to do with park. There are 2 bolts holding the shifter cable to the drivers side of the transmission pan. Make sure they're tight. One of mine wasn't on there when I got the car and it kept coming loose. When I was putting it in park, it would actually be in reverse. That was no good. I tightened the bolt down with the shifter where park should be, got in, moved the shifter all the way down to 1st, then back up to park. I eventually got another bolt to go in place where the other one should have been. I never had that problem or the one with the key since!Originally posted by LETZRIDEI've never touched a rear end before
thanks, i'm gonna take it apart on saturday. i slammed it in park and it locked inCar expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
by ssms5411Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...1 day ago
Working on getting my 99 Camaro back in action. Long story short, got parked in the garage about 5 years ago (kids, career stuff ect.) trying to get her...3 weeks ago
