heat - FirebirdV6.com/CamaroV6.com Message Board
heat
  • heat
    ok well i did my a/c delete a while ago. i still have my heater coil in the there. i took the camaro out the other day and it was cold so i decided to put the heat on. only cold air blew................................... what's my next step
    WAWA-A-HOLIC
    Re: heat
    buy a warmer coat?
      Re: heat
      i wasn't cold, the hubby was b!tching lol. i bundle up...fluffy coats, hats, gloves, scarfts etc. so instead of a new coat, i'll just eat your GUINEA PIG and try to gain some weight!
      WAWA-A-HOLIC
        Re: heat
        idk about your problem. I just wanna see you eat the guinea pig :D
        ~97 3.8L V6 Camaro~
        A few things
        Only Member of Team Hooker?!?
          Re: heat
          I remember that you moved the controls over to the drivers side as well. It sounds like the blend door is not operating properly, maybe one one the lines was disconnected or broken when you moved the controls. If you have good coolant flow through the heater core and the blower motor works, then it is probably the blend door controls.
            Re: heat
            Originally posted by tkoforpresident
            buy a warmer coat?
            HAHAHAHAHAHAHAHA
            87 Firebird RIP
            96 Camaro RS RIP
            94 Patriot Red 1LE Z28 - Sold
            02 WS6 TA - Sold
              Re: heat
              sorry to thread crap, but you arent thinking of selling your ac system, are you?
              i need a new compressor and lines and all of that junk
                Re: heat
                =-0
                Don't eat Norbert!
                  Re: heat
                  don't think that it's the lines, cause i did take that flap door out :)
                  here is what i have left
                  http://forum.camarov6.com/showthread.php?t=83001
                  WAWA-A-HOLIC
                    Re: heat
                    Is the heater core getting hot?
                      Re: heat
                      that is what i was thinking yesterday. i will have to try to get out to the camaro to check.
                      WAWA-A-HOLIC
                        Re: heat
                        The reason I asked is had the same problem on a Cutlass that I used to have. That had two problems.
                        1. There was a valve on the heater hose that stopped the flow when the selector was placed on "MAX AC". In that case the heater core was cold to the touch. Turned out the valve was bad and it was stuck closed.
                        2. After fixing problem #1 I still had no heat. However, the heater core was very hot. I then discovered that the blend door (which moves when you move the selector from cold to hot) was not working properly. I adjusted the cable and I had very hot heat from that day on.
                        If your heater core is getting hot then the issue is under the dash for sure. You mentioned that you removed the blend door. I am wondering if that might be part of the problem. You need the blend door to stop the cold air from mixing with the hot air or you will not have any heat.
                          Re: heat
                          i did the a/c delete, which i took the black holder box out of my car that held everything and now have a plate on my firewall now.
                          where would the cold air be coming from?
                          i only have heat and defrost her now.
                          WAWA-A-HOLIC
                            Re: heat
                            I am not positive where the fresh air enters on our cars. On the Cutlass it entered into the cowl vents just below the windshield.
                            Check the heater core itself first and see if it is hot. Then we can proceed from there.
                              Re: heat
                              yeah that is what i'm going to do...as for the "fresh"air, the only air pulled in is from the mouse wheel.
                              WAWA-A-HOLIC
