park plugs soaked in gasoline - FirebirdV6.com/CamaroV6.com Message Board
  • park plugs soaked in gasoline
    Iam not having a problem with my firebird it is my 1991 ford bronco. When I start it it runs rough. I can smell gas in the exhaust and there is gas on the plug. I changed the cap, rotor,wires and plugs and still runs rough please help me.
    Re: park plugs soaked in gasoline
    A few questions... Is it white? Are there blood stains in the interior? Did the original owner hold you at gunpoint and demand you give him his bronco back?
    Oh btw, if theres gas on and around the spark plugs.. don't blow yourself up :twak:
    TEAM C6V6
      does it have a carb, or is it FI?
        Either way there's obviously fuel leaking from somewhere if I'm reading correctly what you're trying to type. It runs rough because it's not getting all the fuel it should. Just find the leak, if it's as bad as you described.. there should be no problem finding it. Just use some common sense. If I'm way off then find more words to describe the problem accurately. Yes, im a ****head.
        TEAM C6V6
          sounds like your fuel pressure is off. can you get a gauge on there? if not, i would just replace your fuel pressure regulator. your dumping to much fuel.
          WAWA-A-HOLIC
            It's efi. I dont have a Fuel Pressure Gauge. How much do they cost?
              you can get a cheap one for like $20
              i have a fuel pressure/vacuum gauge
                Someones runnin riiiiich. Sounds to me like your fuel pressure regulator is going out. You could also have a(n) bent valve(s), not allowing them to close during the power stroke (or any stroke for that matter)
                • Andy H
                  Transmission removal help!!
                  by Andy H
                • 2.8 Bird
                  Abs inop
                  by 2.8 Bird
                • fishin
                  by fishin
