Iam not having a problem with my firebird it is my 1991 ford bronco. When I start it it runs rough. I can smell gas in the exhaust and there is gas on the plug. I changed the cap, rotor,wires and plugs and still runs rough please help me.
park plugs soaked in gasoline
Re: park plugs soaked in gasoline
A few questions... Is it white? Are there blood stains in the interior? Did the original owner hold you at gunpoint and demand you give him his bronco back?
Oh btw, if theres gas on and around the spark plugs.. don't blow yourself up :twak:Last edited by Blizzard242; 12-03-2007, 10:23 PM.
TEAM C6V6
Either way there's obviously fuel leaking from somewhere if I'm reading correctly what you're trying to type. It runs rough because it's not getting all the fuel it should. Just find the leak, if it's as bad as you described.. there should be no problem finding it. Just use some common sense. If I'm way off then find more words to describe the problem accurately. Yes, im a ****head.
TEAM C6V6
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...12 hours ago
