DOES ANY ONE OUT THERE KNOW HOW TO WIRE A MANUEL FAN SWITCH I GOT ONE OF EBAY AND THE GUY HAD GIVIEN ME THE WRONG DIRECTIONS ANY HELP WOULD BE WONDERFUL THANKS ALOT TREPBOY02@AOL.COM
manuel fan switch NEED HELP!!!!!!
This topic is closed.
-K&N FIPK Air Intake<br />-TB Bypass<br />-Manuel Fan Switch<br />-Stage 2 Jet Chip<br />-Hypertech Powerstat 160<br /><a href=\"http://www.cardomain.com/ride/2023393\" target=\"_blank\">http://www.cardomain.com/ride/2023393</a><br />-UD Pulleys<br />-Adjustable Panhard Bar,STB<br />-BBK Fuel RegTags: None
try a search in the Stereo/electronics forum it has been discussed alot there1994 white Firebird M5<br />Flowmasters, CAI, 3.73s, LSD, coated pacesetters, eibach pro-kit, bilsteins, hurst shifter, JVC stereo, 18\" C5 vette wheels, Kuhmo Ecsta ASX rubber<br /><br /> <a href=\"http://www.cardomain.com/memberpage/744299\" target=\"_blank\">http://www.cardomain.com/memberpage/744299</a> <br /><br />Coming Soon: Turbo!
what do you want to know?
I make and sell them, so i think i can tell you how to wire them, I don't sell the crappy ebay ones though.
But on the ebay ones i have seen, are 4 wires, ground, power, both can be found from the radio harness, or the ciggarette lighter, then you will have 2 wires going to the green and blue wires on pins H and J on connector C100 (10 pin black) you simply use the crappy splice in connectors and hack up your factory wiring. Here is the C100 harness on a 1998+ v8 car
this pic shows the connector you need to splice into http://www.fuelslut.net/hosting/uploads/fanswitch.jpg
Ryan.1998 Ws6 Ta M6 #370 Bright Red<br />Custom \"NX\" style switch panels $35<br />Plug in fan switches $50 <br />SLP lid, Pro 5.0, Corsa, Custom Fan switch<br />....vortech waiting to be installed.
