radiator hose leak - FirebirdV6.com/CamaroV6.com Message Board
radiator hose leak
  • radiator hose leak
    so... my hose has a leak. i found the leak, and need to know what the part number for the hose is. it is the upper hose found [as you are looking into the engine] on the left side. it says, twist and pull. any help would be greatly appreciated. thank you.
    Re: radiator hose leak
    Dont know the number, but I just went into AutoZone and they looked it up and pulled it off the shelf in no time.
    Doug<br />1996 Camaro RS M5 Y87<br />SLP Bilstein shocks, Eibach springs, 1LE frt/rear sway bars
      thank you. that is what i am going to end up doing. :]
