I while back I took off my DIS-4 because it had a violent miss when I would accelerate. I noticed the LED was flashing. I bought a new battery and it still did it.I checked my wiring and grounds and they looked ok. I recently put it back on but the LED is still flashing but no miss yet. Any ideas?
BTW when I completely took off the MSD, the miss went away.
95 Camaro 3.8L Y2K motor <br /><a href=\"http://www.cardomain.com/id/coriya71\" target=\"_blank\">www.cardomain.com/id/coriya71</a>
The DIS 4 maginifies any flaw in the ignition system. So I'd make sure the coil packs are tight, check the wires, and check the plugs. If everything still appears fine, have the coils tested and also test the wires.
Then the possibilities are the CIU's and the coil interface module(the base thingy). The CIU's are cheap; the cim is not(like 80 bucks).
"I ain't too big to listen to the rumors, I'm just too @#$% big to pay attention to them" - Dr. Dre http://seppo.hopto.org/
Well, went for a ride on the freeway for a while and came back, but it's still flashing and there is no miss. I don't know....... [img]graemlins/crybaby.gif[/img]
Great! When driving all day and everything was fine, then went across the street and it died on me!! Couldn't get it started(led was still flashing) so I took it off on the side of the road. :mad: Forget this s#$%^&*t I'm getting rid of it.
